Low Noise 45V-4A Dual Rail Power Supply Using Enhanced Capacitance Multiplier
Hesambook
Full Member level 2
The core element of any electronic device is the power supply. Any instability or malfunction of the power supply causes the device to malfunction or demonstrate weird behavior. In some sensitive applications, we need a dual voltage-rail power supply to prepare a high current and low noise voltage at the output. In this article/video, I introduced a low-noise AC-to-DC power supply that can handle up to 4A continuously and accept input voltages up to 35V-AC.
To design this power supply, I decided to use an enhanced capacitance multiplier circuit. I paid high attention to good grounding, assigned the top layer of the PCB to the ground, and drew power planes instead of tracks to carry high currents. As a result, I could not detect any noise or ripple at the output even at the maximum output current! The PCB board has two layers and to ensure high-quality fabricated boards, I sent the Gerber files to PCBWay.
I tested the board for voltage drop, current delivery, and output noise. I used Siglent SDL1020X-E DC Load and Siglent SDS2102X Plus oscilloscope to perform all tests. I’m confident that this design satisfies your needs in many applications.
Specifications
Input Voltage (max): 35V-AC
Output Current: 4A Continuous
Output Noise/Ripple: Very Low
Output Voltage: 45V-DC (maximum safe, under no load)
Schematic + PCB + Full Detail:
LaTeX Commands Quick-Menu:
