Gaber Mohamed Boraey
Full Member level 3
Hello
That board is inside 3kva ups , it’s inverter board
Take Dc input from 6 batteries in series , battery is 12v lead acid
Then goes to 4 mosfets high and low , every two are together, taking pulses from uc3845 pwm ic
Then goes to chopper then rectifiers then to ups inverter IGBT’s
The black circles where the mosfets installed right and left the board
The yellows are the igbt’s
Here are the mosfets from other side of the board
This UPS came with many parts shorted, igbt’s, some igbt gate driver TL350, also mosfets, and some gates resistors
I’ve checked all and replaced , also found small chopper, this one beside the two big capacitors , open so I replaced with similar one “ but not sure if same coil turns “, can this be the problem?
When I tried to on the ups, damage occurred where are the mosfets, and one diode after the chopper
I’ve replaced and again damage happen
How you think is the problem?, I think it’s before the inverter, as every time the inverter try to start, damage happens
How you think?, do you have any suggest how solve?
