Zuken CR5000 Library export
mstrghettorigg
Junior Member level 1
Hello all,
My situation is that I have the board data (.pcb, .rul) and the netlist in .ccf format. We do not have the library that is used on the board and when I try to forward annotate I get the error saying "error 43052: Part is unregistered in library. [ Part name = 502426-4010 ] [ part library = x:\lib\cdb\xxx.prt ]"
Is it possible to simply export the library from the board data? Or are there any other simple solutions for this problem? If anyone have a solution and could help me out I would really appreciate your help.
Thank you,
You can export the Library from the Board file. that will be Local lib for that Board and after that you can do the forward annotation for that.
Just go to the CAD file manager>select the file>Right Click> Action>Release local Library.
Set the path for this Library or keep exported library in old location of Library.
Hope above will help you
Regards,
Mayank
