Zerner diode can never get ESD damage?
T
treez
....The voltage is clamped to Vf in one direction, and to the zener voltage in the other...so a zener diode can never suffer ESD damage?
Voltage breaks oxides. Current (or Joule heating) kills junctions.
A 2kV HBM pulse peaks at about 1.3A and this can fry integrated
circuit zeners with ease. I have designed and used "zener zap"
devices that can be spiked to short circuits by less than a
hundred mA.
Joule energy, Vz*1A*10uS (very rough) says microjoules in a
few cubic microns (integrated) or maybe a hundred cubic microns
(piece-part, close-in junction volume as thermal time constant
limits how much volume the heat can access). Temperature rise
that can be withstood goes to contact barrier system; pushing
the contact in a bare aluminum (cheapo) contact system past
the silicon-aluminum eutectic temperature will entrain aluminum
and spike the junction.
-Designed- "zener" (breakdown of any sort) devices are used in
ESD protection. GGNMOS clamps are one such. TVSes are another.
Difference being "-designed-", for the threat envelope. A 100mW
glass package zener, stands a pretty good chance of not liking
amperes of pulsed current.
Reactions: treez
    T
If we talk about discrete zener diodes with usual power rating, you probably don't manage to damage it with standard ESD levels. At least I didn't when testing it as protection devices.
Reactions: treez
    T
Thnaks, so if i have a MOSFET on a PCB....and i am worried about getting ESD damage to the FET gate...then all i need to do is to put a zener diode from gate to source (obviously with cathode to gate)...and then the MOSFET will never be ESD damaged.?
Usually a zener should be sufficient to protect a mosfet gate.
But:
* some mosfets have built in protection
* a zener has relatively high capacitance. Check if this can cause problems with high speed switching.
* in none of my designs the gate of the mosfet is connected to a node leaving the PCB. Thus there never was the need to protect the gate against ESD. (ESD always comes from an external source)
Klaus
Reactions: treez
    T
It depends. Expect the zener diode to absorb most of the ESD energy. Fast rising discharge current combined with diode inductance can cause nevertheless 50 or 100 V overvoltage.
Reactions: treez
    T
