cmos babe
Full Member level 4
pull-up yes
Hi I wanted to created a top-level block that contains two 8-bit tristate buffers ,one is connected to the input of a register and the other is connected to the output ...I got this warning :
WARNING:Xst:2042 - Unit zreg: 8 internal tristates are replaced by logic (pull-up yes): into1<0>, into1<1>, into1<2>, into1<3>, into1<4>, into1<5>, into1<6>, into1<7>.
into1(7:0) is the vector signal connecting the output of the first buffer to the input of the register..
