tonionio
Newbie level 6
Dear all.
I am running a synthesis for some componennts of the router I have build in VHDL. My goal is to have latency and throughput resuts for the router.
The thing is thath I am trying to understand the difference between the default period analysis (green) and the following red analysis! What is the difference between them? They represent different delay for paths inside the component? Which one is the dominant and I need to worry about?
In addition to see if I am getting things right! 1) The lower the Level Of Logic the better. 2) The Speed Grade is -3 for this synthesis, where for the VIRTEX-5-6 FGPAs is the on with the better performance right and it defines the timing performance of the device?
Thank you in advance.
Timing constraint: Default period analysis for Clock 'clk'
Clock period: 2.033ns (frequency: 491.836MHz)
Total number of paths / destination ports: 210 / 20
Delay: 2.033ns (Levels of Logic = 3)
Source: pre_req_2 (FF)
Destination: pre_req_2 (FF)
Source Clock: clk rising
Destination Clock: clk rising
Data Path: pre_req_2 to pre_req_2
Gate Net
Cell:in->out fanout Delay Delay Logical Name (Net Name)
FDRE:C->Q 5 0.361 0.530 pre_req_2 (pre_req_2)
LUT5:I2->O 8 0.097 0.543 mask_pre<2>1 (mask_pre<2>)
LUT5:I2->O 2 0.097 0.299 GND_4_o_mask_pre[4]_not_equal_11_o (GND_4_o_mask_pre[4]_not_equal_11_o)
LUT6:I5->O 1 0.097 0.000 Mmux_win32 (win<2>)
FDRE 0.008 pre_req_2
Total 2.033ns (0.660ns logic, 1.373ns route)
(32.5% logic, 67.5% route)
Timing constraint: Default OFFSET IN BEFORE for Clock 'clk'
Total number of paths / destination ports: 211 / 30
Offset: 1.950ns (Levels of Logic = 4)
Source: full_local (PAD)
Destination: pre_req_4 (FF)
Data Path: full_local to pre_req_4
Gate Net
LUT4:I0->O 8 0.097 0.715 Madd_req[4]_GND_4_o_add_9_OUT_cy<2>11 (Madd_req[4]_GND_4_o_add_9_OUT_cy<2>)
LUT5:I0->O 1 0.097 0.000 Mmux_win5_SW0_SW0_G (N54)
MUXF7:I1->O 1 0.279 0.379 Mmux_win5_SW0_SW0 (N41)
LUT6:I4->O 1 0.097 0.000 Mmux_win5 (win<4>)
FDRE 0.008 pre_req_4
Total 1.950ns (0.855ns logic, 1.095ns route)
(43.9% logic, 56.1% route)
Timing constraint: Default OFFSET OUT AFTER for Clock 'clk'
Total number of paths / destination ports: 5 / 5
Offset: 0.361ns (Levels of Logic = 0)
Source: grant_q_4 (FF)
Destination: grant<4> (PAD)
Data Path: grant_q_4 to grant<4>
Gate Net
FDCE:C->Q 1 0.361 0.000 grant_q_4 (grant_q_4)
Total 0.361ns (0.361ns logic, 0.000ns route)
(100.0% logic, 0.0% route)
Timing constraint: Default path analysis
Total number of paths / destination ports: 1 / 1
Delay: 0.113ns (Levels of Logic = 1)
Destination: wr_en_local (PAD)
Data Path: full_local to wr_en_local
Gate Net
INV:I->O 0 0.113 0.000 wr_en_local1_INV_0 (wr_en_local)
Total 0.113ns (0.113ns logic, 0.000ns route)
Gate Net
Gate Net
Gate Net
Gate Net
