kemes
xcf08p
Hi to all
I'm attempting to program the device using parallel port and my own code.
I can erase, blank check, readID, and read a single 256 bit page using a simple parallel port connected to the device. Sometimes the TAP jtag state machine returns 0xff whatsoever actions I do, so I should reset it. Moreover when I start programming, after some pages the result is an error, either if I check the OP_STATUS register and the response is "ready" (0x36). In this situation I can't recover. Someone experienced something in programming this device?
Hi to all
