Alper özel
- Joined
- Feb 28, 2015
- Messages
- 40
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Location
- Turkey / Scotland
- Activity points
- 487
I am trying to see the schematic output of my verilog module in Xilinx ISE. However, I am getting this silly error:
Here is the counter_4 module:
I ve already tried restarting both ISE and computer but they did not help. So I am asking for help from experienced FPGAdevelopers. Here the top module I want to sythesize:ERROR:Xst:2369 - Empty project file "C:\Users\aozel\Desktop\Verilog Projects\trial_one\trial_one\receive_byte.prj"
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 16:19:35 01/05/2016
// Design Name:
// Module Name: receive_byte
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
`include "counter_4.v"
module receive_byte(
input [0:0] clk,
input [0:0] enable_to_rx_byte,
output reg [7:0] rx_byte,
output reg [0:0] rx_done,
input [0:0] sda_to_rx_byte,
output reg [0:0] scl_flag_from_rx_byte,
input [3:0] flags_from_ctr_4,
output reg [0:0] en_to_ctr_4,
output reg [0:0] rst_to_ctr_4,
output reg [0:0] rst_to_ctr_4_done,
output reg [2:0] rx_ctr,
output reg [0:0] mode_to_ctr_4,
input [15:0] ctr_4
parameter data_rate_khz = 0;
integer N_to_scl_div = 500000 / data_rate_khz;
always @(posedge clk) begin
if (enable_to_rx_byte !== 1'b1) begin
rx_done <= 1'b0;
en_to_ctr_4 <= 1'b0;
rst_to_ctr_4 <= 1'b0;
rx_ctr <= 3'b111;
end
else if (enable_to_rx_byte === 1'b1) begin
en_to_ctr_4 <= 1'b1;
mode_to_ctr_4 <= 1'b1;
if (rx_done !== 1'b1) begin
if (flags_from_ctr_4[0] == 1'b1 && flags_from_ctr_4[3] === 1'b0) begin
scl_flag_from_rx_byte <= 1'b0;
if (ctr_4 == N_to_scl_div * 3 / 4) begin
rx_byte[rx_ctr] <= sda_to_rx_byte;
if (rx_ctr == 3'b0) begin
rx_done <= 1'b1;
end
else if (rx_ctr != 3'b0) begin
rx_ctr <= rx_ctr - 1;
end
end
end
else if (flags_from_ctr_4 == 4'b0000) begin
scl_flag_from_rx_byte <= 1'b1;
end
else if (flags_from_ctr_4 === 4'b1000) begin
end
end
end
end
always @(negedge clk)
begin: RESETTER_TO_CTR_4
if (en_to_ctr_4 !== 1'b1) begin
rst_to_ctr_4 = 1'b0;
rst_to_ctr_4_done = 1'b0;
end
else if (en_to_ctr_4 === 1'b1) begin
if (!rst_to_ctr_4_done) begin
rst_to_ctr_4 <= 1'b1;
rst_to_ctr_4_done <= 1'b1;
end
else if (rst_to_ctr_4_done) begin
end
end
end
counter_4 u1(
.rst (rst_to_ctr_4),
.en (en_to_ctr_4),
.mode (mode_to_ctr_4),
.clk (clk),
.flags (flags_from_ctr_4),
.comp_A (N_to_scl_div / 2),
.comp_B (0),
.comp_C (0),
.comp_D (N_to_scl_div),
.ctr (ctr_4)
endmodule
// Company:
// Engineer:
// Create Date: 16:36:48 01/05/2016
// Design Name:
// Module Name: counter_4
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
module counter_4(
input [0:0] rst,
input [0:0] en,
input [0:0] mode,
input [0:0] clk,
output reg [3:0] flags,
input [15:0] comp_A,
input [15:0] comp_B,
input [15:0] comp_C,
input [15:0] comp_D,
output reg [15:0] ctr
//reg [15:0] ctr;
if (rst) begin
ctr = 16'b0;
flags = 4'b1000;
end
else if (!rst) begin
if (en) begin
ctr = ctr + 1;
if (mode) begin
if (ctr != comp_D) begin
if (ctr == comp_A && comp_A != 16'b0) begin
flags[0] = 1'b1;
end
else if (ctr == comp_B && comp_B != 16'b0) begin
flags[1] = 1'b1;
end
else if (ctr == comp_C && comp_C != 16'b0) begin
flags[2] = 1'b1;
end
end
else if (ctr == comp_D && comp_D != 16'b0) begin
flags = 4'b0;
ctr = 16'b0;
end
end
else if (!mode) begin
flags[0] = 1'b1;
ctr = 16'b0;
end
end
end
else if (!en) begin
flags = 4'b1000;
end
end
end
endmodule
