Xilinx IP CORE FFT: Missing signals/functions
Wild Life
Member level 1
Dear All, I realized an FFT via IP CORE in Xilinx Ise (virtex 5), the problem is that FFT hasn't input enable! So I should have the entire stream of samples to elaborate one sample-per-clock (without missing spaces)! Without other cores when I hadn't samples available I simly put input_enable as '0' waiting for samples' availability. Now, this can't be me made: in N-1 clock cycles i shouls have k-1 samples available... there's a way to have the input-enable function or I'm forced to have the entire frame available?
Well this is quite hard to decipher what you're actually asking, but i think a FIFO is what you're looking for. Just buffer your data and when you have enough to do your fft, stream it out of the FIFO into the FFT as one continuous data stream. There's a FIFO generator in coregen.
