Amra
Newbie level 5
Hello everyone!
I am working on X-band reflect Array antenna and making the copy of a design from a research paper on HFSS. basically my design has an outer circular ring and in it is an I-shaped dipole. I've made the radiation box which is lamba/4 above the substrate and the lambda i used is of lowest frequency in the band 9.5GHz-11.5GHz.the solution frequency is 10.5GHz. I have used one floquet port on the top of radiation box and Master/slave boundaries. max no of passes are 6 and max delta s is 0.02. now when i analyze my design it says "Adaptive passes did not converge on specified criteria" and moreover the results are too much change from the results of research paper. I've tried many things changed the length of radiation box by taking the lambda of solution frequency in lambda/4, increased the no of passes up to 15, redesigned my whole design but nothing worked.:sad: .i really need to get the desired results in a day or two. please help me finding the problem. I shall be grateful.
I have attached both the research paper and my hfss design
