member_tdh
Member level 5
Hi!
My project's work is: reat data from COM port, then report data into a text file but my result is:
"textfile.txt"
E1234567
E12345678910
I don't know why it error!
Could anybody help me!? Thanks so much!
Private Sub MSComm1_OnComm()
Dim k As Long, i As Long
Dim Buffer As Variant
Dim BytesReceived() As Byte
Dim sRxData As String
Dim sRD As String
Dim FileNum As Byte
Dim FileName As String
FileNum = FreeFile
FileName = "C:\Documents and Settings\khac trung kien\Desktop\DataApr2008.txt"
Open FileName For Append As #FileNum
With MSComm1
If .InBufferCount >= 1 Then
nCount = nCount + .InBufferCount
Label4.Caption = nCount
Label4.AutoSize = True
Select Case .CommEvent
Case comEvReceive
'Buffer = .Input 'Get serial Data
'BytesReceived() = Buffer
sRxData = sRxData & MSComm1.Input
If sRxData = "" Then sRxData = 0
For i = 1 To Len(sRxData)
Text2.Text = Text2.Text & Hex$(Asc(Mid$(sRxData, i, 1)))
Next
Print #FileNum, Text2.Text
Close #FileNum
.InBufferCount = 0
End Select
End If
'Debug.Print "Receive - " & Text2.Text
'DataLog (Text2.Text)
End With
End Sub
"textfile.txt"
E1234567
E12345678910
Dim sRD As String
Dim FileNum As Byte
FileNum = FreeFile
With MSComm1
Case comEvReceive
Next
Close #FileNum
.InBufferCount = 0
End Select
End If
End With
End Sub
