YL12413
Newbie level 2
Hi, there:
First of all, I would like to say thanks for any help.
I just started coding in VHDL and created FSM, but when I tried to start the simulation, there was the error:
Error: (vsim-3174) Package 'H:/VHDL/project1/work.config_pack' requires a body.
which really confused me, maybe any of you may help me out?
the following will be the code:
and here is the testbench:
Thanks a lot!!!!
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 USE STD.TEXTIO.ALL; LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; PACKAGE config_pack IS CONSTANT config_clock_period : time := 1000 ns; -- period of clock as one micro second CONSTANT config_post_cycles : integer := 100; -- idle cycles waiting for new potential new config commands CONSTANT post_command_delay : time := config_clock_period * config_post_cycles; ----potential config commands with 3 bits------ ALIAS slv IS std_logic_vector; CONSTANT off : slv(2 DOWNTO 0) := "000"; --pulse generator is inactivated CONSTANT vol_m : slv(2 DOWNTO 0) := "001"; --programmed to voltage mode CONSTANT cur_m : slv(2 DOWNTO 0) := "010"; --programmed to current mode CONSTANT vdd : slv(2 DOWNTO 0) := "011"; --pull the output to VDD CONSTANT charge_balance : slv(2 DOWNTO 0) := "100"; --maybe need to be charge balance CONSTANT gnd : slv(2 DOWNTO 0) := "111"; --maybe gnd ---------------------------------------------------------------------- TYPE STATE_T IS (PNEG, PPOS, PSHT, PINT); CONSTANT TN : INTEGER; --NEGATIVE PHASE WIDTH CONSTANT TP : INTEGER; --POSITIVE PHASE WIDTH CONSTANT TI : INTEGER; --INTERMEDIATE PHASE WIDTH CONSTANT TS : INTEGER; --SHORTING PHASE WIDTHx CONSTANT PULSE_N : STD_LOGIC_VECTOR(1 DOWNTO 0):="10"; CONSTANT PULSE_P : STD_LOGIC_VECTOR(1 DOWNTO 0):="01"; CONSTANT PULSE_S : STD_LOGIC_VECTOR(1 DOWNTO 0):="11"; CONSTANT PULSE_Z : STD_LOGIC_VECTOR(1 DOWNTO 0):="00"; END; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE WORK.PROJECT_PACK.ALL; USE WORK.CONFIG_PACK.ALL; ENTITY FSM_PULSE IS PORT( CLK, RESET : IN STD_LOGIC; CONFIG : IN STD_LOGIC_VECTOR(2 DOWNTO 0); start : IN STD_LOGIC; Pulse : OUT STD_LOGIC_VECTOR(1 DOWNTO 0) ); END FSM_PULSE; ARCHITECTURE FSM_BEHAV OF FSM_PULSE IS SIGNAL STATE, STATE_N : STATE_T; SIGNAL COUNTER : INTEGER RANGE 0 TO (TN+TP+TI+TS); SIGNAL PULSE1 : STD_LOGIC_VECTOR(1 DOWNTO 0); BEGIN S_PROC: PROCESS(STATE, STATE_N, COUNTER) BEGIN STATE_N <= STATE; CASE STATE IS WHEN PPOS => PULSE1 <= PULSE_P; IF (COUNTER = TP) THEN STATE_N <= PINT; END IF; WHEN PINT => PULSE1 <= PULSE_Z; IF (COUNTER = TP + TI)THEN STATE_N <= PNEG; END IF; WHEN PNEG => PULSE1 <= PULSE_N; IF (COUNTER = TP + TI + TN)THEN STATE_N <= PSHT; END IF; WHEN PSHT => PULSE1 <= PULSE_S; IF (COUNTER = TP + TI + TN+ TS)THEN STATE_N <= PPOS; END IF; WHEN OTHERS => NULL; END CASE; -------------------------OUTPUT THE PULSE ONLY IF IT IS ENABLED----------------------- IF START='1' THEN PULSE <= PULSE1; END IF; END PROCESS S_PROC; C_PROC: PROCESS BEGIN WAIT UNTIL CLK'EVENT AND CLK='1'; STATE <= STATE_N; IF RESET = '1' THEN STATE <= PPOS; COUNTER <= 0; END IF; COUNTER <= COUNTER + 1; END PROCESS C_PROC; END ARCHITECTURE FSM_BEHAV;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; USE work.project_pack.all; USE std.textio.ALL; USE WORK.CONFIG_PACK.ALL; ENTITY FSM_testbench IS END FSM_testbench; ARCHITECTURE behav OF fsm_testbench IS -- FSM_PULSE SIGNAL CLK_I : STD_LOGIC; SIGNAL RESET_I : STD_LOGIC; SIGNAL CONFIG_I : STD_LOGIC_VECTOR(2 DOWNTO 0); SIGNAL start_I : STD_LOGIC; SIGNAL Pulse_I : STD_LOGIC_VECTOR(1 DOWNTO 0); -- needed as parameters for run_command_file but not -- used since it is called with ram_mode_v=model SIGNAL cycle_init, cycle_done : STD_LOGIC; -- dummy signals SIGNAL trace_commands: boolean := false; BEGIN FSM1: ENTITY WORK.FSM_PULSE PORT MAP( CLK => CLK_I, RESET => RESET_I, CONFIG => CONFIG_I, start => START_I, Pulse => PULSE_I ); P_RST_CLK: PROCESS -- generate reset_i & clk_i BEGIN -- first ten cycles with reset '1' reset_i <= '1'; clk_i <= '0'; FOR n in 0 TO 9 LOOP WAIT FOR config_clock_period / 2; clk_i <= '1'; WAIT FOR config_clock_period / 2; clk_i <='0'; END LOOP; reset_i <= '0'; -- now generate continuous clock with reset '0' WHILE TRUE LOOP clk_i <= '0'; WAIT FOR config_clock_period / 2; clk_i <= '1'; WAIT FOR config_clock_period / 2; END LOOP; END PROCESS P_RST_CLK; END behav;
Thanks a lot!!!!
