ejleiss
Junior Member level 2
Hello,
I've been trying to work with the WIZ110SR to setup a quick test between the gateway and a serial port on another computer. I can't seem to get things working correctly. Once the setup parameters are loaded to the WIZ I should be able to communicate using RealTerm or any other hyperterminal program correct? I see the TX line on the serial DB9 is at -5V?? Has anyone else had this experience or could direct me to some better documentation than the datasheet?
Thank you.
Thank you.
