Will abstract class object be created?
jdshah
Junior Member level 3
Ahmedabad
When we call new constructor for derived class, system verilog will call new for base class automatically. Memory for base class will be automatically created. Derived class can not be created with out creating parent class.
"A super.new call shall be the first statement executed in the constructor. This is because the superclass
shall be initialized before the current class and, if the user code does not provide an initialization, the
compiler shall insert a call to super.new automatically."
My question is if base class is abstract class then also it is created by creating derived class? Will its memory be created?
Yes it will. Abstract (virtual) classes can contain as many variables, functions and tasks as you like. But they cannot be created directly, they have to be created by using a derived class.
Its quite common to have an abstract base class to define specific behaviour. look at the below example
virtual class shape;
  integer n_sides;
endclass : shape
class square extends shape;
  function new;
    super.n_sides = 4;
  endfunction : new
enclass : square;
square x;
x = new;
$display("%d", x.n_sides);
  integer n_sides;
endclass : shape
  function new;
    super.n_sides = 4;
  endfunction : new
enclass : square;
square x;
x = new;
Thanks TrickyDicky. It cleared my query.
SV 2012 allows a slightly improved instantiation method:
shape x[3];
x[0] = square::new;
x[1] = triangle::new;
x[2] = hexagon::new;
for(int i = 0 ; i < x.size() ;i++)
  $display("shape = %s , n_sides = %d", x[i].get_name(), x[i].n_sides);
Reactions: jdshah
    jdshah
