MetalLord said:oh ok ! Thanks a lot for the suggestion, will try with this approach.
amarnath said:yes dc sweep is the best way, i just told you an alternative to dc sweep and also a method by which your transient result can match the result of your dc sweep.
amarnath
strennor said:First of all, we talk about Vil/Vih or Vol/Voh only for Logic circuits.
DC sweep sometimes suffers convergence problem. So we can try tran.
When do tran sim, make sure the rising/falling time is long enough so that the results are close enough to DC results.
To onlymusic16:
plot your Vo vs Vi
the cross point is Vil or Vih, depends your input (ramp down or up).
For Vol or Voh, it defines with specific output driving. Fix your input, the output is either H or L, then source or sink a fixed current (per your spec), measure the Vo.
