why the equation density carrier electron vs temperature don't fit with the graph of book?
stackprogramer
Full Member level 3
why the equation density carrier electron vs temprature don't fit with graph of book?
hi,in link https://www.iue.tuwien.ac.at/phd/wittmann/node7.html that it is too there is in yang micro device,there is a graph that can see below:
the equation of carrier is below
our default is NA=0 and we have n-type silicon, when i plot this equation in matlab we don't arrive this graph!!11
clc
clear
Nd=10^16;
Eg=1.4;%ev
K=8.6173324*10^(-5);%ev
m0=9.109*10^-31;
me=1.08*m0;
mh=.56*m0;
h=4.135667662*10^(-15);%ev
y=@ (T) 1/2+1/2*(1+16*(6.28*K*T*(me*mh)^.5*(1/h^2))^3*exp(-Eg/K*T)*1/Nd^2)^.5;
fplot(y,[1,2]);
the output from matlab is here:
why i do wrong?!!!:sad:
Re: why the equation density carrier electron vs temprature don't fit with graph of b
Are You sure that every number used in your formula is float?
a snapshot from workspace matlab:
these varribles all are float,thanks for replay
i think we should use other equation!where i should find equations!
Re: why the equation density carrier electron vs temprature dosn't fit with graphof b
why i do wrong?
Apart from the fact that I cannot judge if
1. this equation can really regenerate the graph
2. NA=0 is a valid assumption for this calculation
3. your MATLAB command file is correct
... I suspect your MATLAB program couldn't find your command file.
In any case I'd suggest to use a log scale for the y-axis.
i talk that this post is from microelectronic devices s.yang is about semiconductor,fabrication,inetgrated circuit is not phyisics it is physics of semiconductor in engineer electronic.please change to my category.
thanks
i suspect my wrong is here,but i think that how i find and calculate equation
thanks for replay
... is from microelectronic devices s.yang is about semiconductor,fabrication,inetgrated circuit is not phyisics it is physics of semiconductor in engineer electronic.please change to my category.
... is not physics (!) it is physics of semiconductor ...
Right: it is physics, but has nothing to do with IC design, layout & fabrication, that's why I had transferred it to the math & physics section. I think you've more chances to get help here.
As you might notice, your thread is still accessible from the Analog Integrated Circuit (IC) Design, Layout and Fabrication section.
Checking the equation parts shows that exp(-Eg/K*T) is effectively zero, so the constant 1 output is expectable.
Don't see how you arrived at the equation. Maybe just a typo.
Those equations do not describe carrier freeze-out effect - they are applicable only for temperature above freeze out.
The plot is correct, but it does not correspond to those equations.
Equations accounting for carrier freeze out effect should involve impurity activation energy.
Under carrier freeze-out, ionized impurity concentration is lower than the total impurity concentration, so the equation (2.19) is not valid.
I think the physics of semiconductor devices is directly related to analog circuits...
you are right,but i conclude that this equation is n't for curve.
yes,i should find the equation for ionization,extrinsic,intrinsic state and i plot.
but where is these equations!its not in refrence s.yang ben G streetman,
i am searching.............
A PhD of physics can't answer of these question ,a electronic guy can solve it.but you are moderator and you should decide
thanks for accessing my post in analog circuit
i am unanimous you.
The subexpression doesn't seem right for any meaningful equation, I guess either the parameter values or the equation has a typo.
its adaption from s.yang microelectronic device page 19 thanks
I found many errors in your matlab code and in your math. First of all I think is better to have anything in MKS system, then:
h=6.626e-34
K=1.38e-23
1eV = 1.6e-19J that means Eg=1.12*1.6e-19
In the exponential you wrote exp(-Eg/K*T) that due to the precedence of the operators T is at the numerator. The correct code is instead exp(-Eg/(K*T)).
However ni2=Nc*Nv*exp(-Eg/(K*T)) where
Nc=2*(2*pi*me*K*T/h2)3/2
Nv=2*(2*pi*mh*K*T/h2)3/2
then Nc*Nv=4*(4*pi2*me*mh*K2*T2/h4)3/2
that is: Nc*Nv=32*(pi*sqrt(me*mh)*K*T/h2)3
so: ni2=32*(pi*sqrt(me*mh)*K*T/h2)3*exp(-Eg/(K*T))
this result can be used in the main equation:
nn = 0.5*{ND-NA+sqrt[(ND-NA)2+4*ni2]}
I hope now it's correct. Please check.
However I don't think you can see the freeze-out region from this equation, but you should see the extrinsic as well as the intrinsic region.
Pay attention to the measurement units: the result of the equation is in m-3 while the graph is in cm-3 so you have to multiply by 106. The same apply to ND that has to be set in m-3
A question: why do you assume NA=0 ?
Reactions: FvM
    FvM
but my code run in matlab 2015 and no have errors!
i am know this rule.thanks for reply.
because we have n-type semiconductor.thanks for attention.
finally i conclude this equation is not for this curve the equation i find in Robert F. Pierret-Advanced Semiconductor Fundamentals-Prentice Hall (2002).pdf page 122
the equation image is in below.
i finally succeed i ploted density of electron /ND vs temprature ,these are output,
the equations i found in Robert F. Pierret-Advanced Semiconductor Fundamentals-Prentice Hall (2002).pdf page 122
if we increase ND=10^16 1/cm^3 to ND=10^17,10^18,10^19 the curve chnages according:
1)the graph shifts to right,ionization donor temprature increase
too instrinsic region shifts a little right.
2)the linear region(Exrinsic region) decrease in semiconductor,it is not good for us or semiconductor industrial.
soon source and files will be shared.thanks
