Why NAND and NOR gates are more common than AND and OR gates?
eugenehhk
Member level 1
THX:)
and vs nand
You can implement any gate from NAND or NOR gate but you can't do so with AND or OR gate .In addition the NAND and NOR implementation(in popular logic families) is more simple than AND or OR gate .
NAND VS AND
In addition,a NAND gate has the smallest propagation time delay among other gates (except for the inverter). Thus, it's the basic building block of all logic circuits.
NAND VS AND
nand nor are universal gates we can make any gate from these gates
Re: NAND VS AND
NAND and NOR are Universal gates while others are normal gates .
You can form any of the other gates using these universal gates .
Re: NAND VS AND
When designing Gates, it's not possible to design AND and OR gate direcly. But you can design NAND and NOR simply and convert them via NOT gate.
"Don't Forget To Help"
Re: NAND VS AND
NAND and NOR gate more popular because of all other gates can realized by using NOR gate only or NAND gate only. So they are called universal gate. This is possible by solving Boolean equation of gates using Demoragan’s law. Even NAND gate is realized by NOR gate and vice versa.
with regards
Ajish Babu S
Re: NAND VS AND
These answeres are true, but dont forget that NAND is easy to make in MOS technologies....
Re: NAND VS AND
NOT, NAND and NOR are the base of modern digital design.
The reasons are:
1. NAND and NOR have smaller area than AND and OR
2. NAND and NOR are faster working
3. All of more dificult devices are built from theese elements. Look for any trigger.
Re: NAND VS AND
Added after 15 minutes:
hey then does that mean that implementing NAND and NOR gates in circuit level is easier than implementing AND and OR gates...
Re: NAND VS AND
Yes it does... With nand or nor gate you can make any other gate, even inverter... That means you will need only nand or nor for your circuit...
NAND VS AND
for two reasons :
1)NAND gates use fewer transistors than AND gates and circuit implementation using NAND gates will result in a smaller area in the IC.
2)NAND gates are faster than AND gates
