WHY IS DWT IN OFDM IS BETTER THAN FFT ??
akmirror
Junior Member level 3
fft ofdm
hi all..i m doing my project in performance analysis of OFDM using discrete wavelet transform instead of FFT which is normally used....
I just want to know why is there a need for DWT to be used in OFDM...what r the drawbacks of FFT in OFDM....????...
thanks...
fft in ofdm
my friend, can i ask you a favore? may i know how to use the DWT insteade the FFT?
thanks...
Why would you want to use discrete walsh transform instead of FFT? lets leave the technical stuff alone, fft is the most efficient transform there is .... correct me if I'm mistaken!
implementing ofdm based on dwt
i have heard that DWT is good than FFt for so many reasons....
FFT only gives frequecny resolution but no time resolution however wavelet transform gives both the frequency and time resolution.
In case of OFDM spectral efficiency increases if DWT is used than FFT . thats why..but can u ppl share much about it
Added after 2 minutes:
hey dear fren DWT that i m referring to is Discrete Wavelet Transform ....
DWT is far better than the fourier transform. isn't it??
wavelet ofdm basics
Yeah, I was thinking why would one want to use a Walsh transform. But I have also been thinking of the use of wavelet transform for OFDM but I think the processing required for Wavelet is more than what is required for FFT
But it is certainly something that does interest me, although I must also confess I know very little about Wavelet transforms
dwt ofdm
DWT and FFT represent the same signal. So the question is which transform is more natural to channel properties or more efficient in terms of hardware.
Channel equalization is similar.
But more efficient channel coding requires that the data is unique within a specific frequency band. That favors FFT!
how to use dwt
yes wavelets are a good tool for understanding signal properly...
Can u guys help me?...
Can i get a simulink model in matlab of OFDM that uses DWT i.e the discrete wavelet transform instead of FFT...any suitable codes or model in matlab..i m not looking for it...but haven't been able to find the exact one....
If anyone have any info abt this...plz post or mail me
akmirror@hotmail.com.......thanks
fft importance in ofdm
Hi friends,
can i have a reference to understand the wavelet transform from the communications point of view? even if you have a web link this is not a matter
Thank you
dwt in matlab
I had a webinar for DWT for communication. It was mathworks' webinar, it wasn't detailed but still gave a good understanding of how to use DWT in matlab and its basics also. Try to find it at mathworks.com in the recorded webinars section
why fft used in ofdm
Many thanks my friend
