are you using the correct version of assura that corresponds to your version of IC? for IC61x you need assura OA, for IC5x you need assura CDB. to check your assura version type
assura -W
if it says dfII5.1.41 you are using assura CDB
if it says dfII6.1.3 you are using assura OA
I have the same problem as fuser1972.
Where should I type "assura -W"? I've tried typing it in different directories but it returned "command not found"...
Actually I found out that I didn't have assura installed. Now I can see the button in the layout editor but I still have problems with the LVS check (it returns an error message about unbound devices)...
