Why base and emitter are connected?
EDA_hg81
Advanced Member level 2
I saw a design like the attached picture.
Thanks.
:cry:
The 140ohm resistor provides base discharge, take
the case that your "Vout" has limited sink drive (a
unidirectional current source). A roughly 5mA sink
is provided (700mA/140ohm).
If the source can't be relied upon to sink current,
say under startup or fault conditions, the resistor is
going to make the output go to a known, 0 voltage.
    EDA_hg81
It is not shorted. Current first flows thru the 140 ohms and when the current is ~5mA, it creates a Voltage drop of 0.7V at which time the BJT will turn on.
The circuit ensures that the buffered output doesnt go much below 0.7V of Vout.
    EDA_hg81
So many thinks for your sincere explanations.
I am wondering if the above and this attached design have the same functions.
Which one is better?
Similar. But the first one has a lower effective base
impedance (so probably better transient behavior
especially low-going) and the input current varies
little w/ output voltage (always Vbe/140) , while the
second will have a significant variation (R1 sees 0 to
(VOH+Vbe), depending).
    EDA_hg81
i'm a newbie but i'd like to ask...
is it something to do with negative feedback? i.e. feeding back a portion of the output back into the input signal.. like in an op amp. ?
    EDA_hg81
The input impedance is increased. The 140 ohm resistor is boosted by beta times.
The 100 0hm resistor in the second diagram is for oscillation prevention. With a capacitive load the input impedance can have a negative real part.
When I design RF power amplifiers, I always put a few ohm resistor in series with the input. So do many other designers.
    EDA_hg81
Thank you so muck for your sincere answer.
Best Regards.
