Why azimuth resolution is 1.4deg? And elevation is 18deg?
tony_lth
Advanced Member level 5
Beijing
Hi, Gurus,
I found in the TI AWR2243 pdf, it says in 2.3.1:
86 element virtual array – enabling 1.4 degree angular resolution
4 element virtual array – enabling 18 degree angular resolution
I am curious how to determine 86 element?
The radar antenna layout as the picture, the upper is 16 RX antennas, the lower is 12 TX antennas. Each IC has 3TX and 4RX.
Best,
Tony Liu
--- Updated ---
And I found the elevation 4 elements array are not spaced equevalently.
So how to determine the elevation resolution is 18deg?
--- Updated ---
In Fig6, it demos the arrays.
And in Fig7, it present the simulate results.
I wonder how to get Fig7 results in matlab? how to program?
  • 雷达校准方法tiduen5a Imaging Radar Using Cascaded mmWave Sensor Reference Design (Rev. A).pdf
Since one byte contains 256 possible values, it's convenient in some computer calculations to divide a circle into 256 units called brads (instead of degrees or radians) (in no way related to my first name). One brad is 1.40625 degrees.
