Who can manufacture one prototype of a PCB?
yassin.kraouch
Advanced Member level 2
has anyone an idea about a manufacturer who can manufactuer one prototype of my own circuit??
PCB
Do you mean a bare PCB or to assemble it as well? For bare PCBs I use PCB-Pool.
Keith
Re: PCB
no it is not barePCB, yes i find PCB pool in the internet, but how cani assemble my PCB, what is the file needed to get a PCB and how type of payment they accept?? my PCB is SMD,
PCB
You must have a "BOM" = component listing with all relevant data for the ordering of pieces/Components, as (ev. preferred)producer/Type Nr,versions codes, event. Distributors/sources who you prefers...
Than tolerances/power/Work-Voltages/size(SMD)...
All data for absolutly clear determinating a component!
For populating from a firm (f he will make it automated) you need a mask film/data-file (schablone for solder paste printing) and a file with Pick-Up points/data-file (or you have their on your components/library) as i.e. glue points too if an SMD PCB is both side populated (in the library to deliver from you as best...)...
Of course a montage schema/populations drowing with all your ref-des on right place & as best the values from your components too.
To end eventuell some specifical montage instrucions... These is relative easy :)
If it will manuell populated, some simpler is your process/less documents are needed, but more time too for tho working personal: usual is than more expensive...
Regularly is better to say to a firm; "(as general undertaking/firm), buy for me components, order the PCB from your partner/vendor & populate/event. test too the card; you have some easyer/quality is better and so on...
K.
