venerable13
- Joined
- Aug 25, 2010
- Messages
- 5
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Valencia, Spain
- Activity points
- 1,318
1-I use Footprint maker for Orcad 16.3 but when I generated the footprint and select pcb editor can't see it, it seems that it's designed for Allegro because if I put generate and then select allegro the footprint appears. Which is the difference to use one or the other because I'm using pcb editor. If the differences are minimum I prefer to use Footprint maker than pcb editor and can't dispose of a lot of footprints in seconds
2-Then, if I use Footprint Maker and the footprint is generated, how can I use it? Because if I generate a footprint, in C://MYSYM appears a lot of archives, I copy all to my library directory and I can use it, but what is the exactly way to operate with it?
What exact archives should copy to my library because in any footprints the generation of archives is very big. For example, if I create a header of 20 pins in C:// MYSYM is generated "tira20pines-1x2.psm", tira20pines-1x3.psm ...... to "tira20pines-1x20.psm" a rang of a lot of archives when I only need "tira20pines-1x2.psm". How you use this program to obtain a footprint the quickest way possible (the steps), because I don't see a tutorial.
3-Is there a form to watch in Capture the footprints without open pcb editor or allegro? Other form to navigate for the menu libraries that not to be place - manually and ticking the part to watch it (I hate to tick the box in the part to watch it)
4-Can I change a footprint in allegro or pcb editor if I commit an error in capture? How? In properties of the part?
5-If I change a footprint in capture when I have pcb editor or allegro open this footprint changes in them in real time? How can ability this if by default I can't get it?
6-Which is the difference between Orcad Capture an Capture CIS?
Thanks!
It is a community very extensive and specialiced, GO ON!
Can anyone say to me any others community of orcad 16.3?
Thanks!
