Which is better language for GUI development
kalyansrinivas
TCL or C++ ,VB or using Matlab
Which will be fast and can be used for porting the bit/sof file into FPGA
Some random opinions:
VB sucks.
C++ is nice. If you want C++ with GUI flavor, consider looking into Qt.
TCL might make sense if you have to script something and there's already a fpga related library for you to program against.
Matlab is nice, but I don't readily see the connection between matlab and your random sequence of words.
So all in all **broken link removed** or Tcl I'd say...
Thanks for the reply
Can u give me some good reference for fpga related library for programming the bit/sof files
I understand from this is that matlab gui cannot be used for programming the bit/sof files
For FPGA developer learning c++ might be difficult
If i choose tcl , Is tcl based gui is faster and better than c++
Not really. What I meant is: fpga tools typically have some tcl APIs. To give an example ... for xilinx ISE I can use chipscope functionality from my tcl scripts.
I didn't say that. But what I am saying is that it is not the most obvious match. :p
No. :p
But who cares about "faster" in this context? Is your bit/sof programming done through the medium of an first person shooter? No? Well, then don't worry too much about speed. Tcl/Tk based gui is going to be "slower" than a proper C++ based gui. But who cares. As long as it's fast enough...
And by bit/sof files programming, I assume you mean the files already exist, and you just have to stream them via jtag or something? If so, doesn't that sort of application exist in like 246324 varieties?
You havent really said what context the GUI is in? What do you need it to do? Are you trying to run a GUI on an FPGA?
FPGA vendors have tools that do the programming, and like mrflibble says have TCL apis you can hook into.
Thanks mrflibble for the answer
TrickyDicky : I am looking for developing gui that runs on PC for porting the FPGA bit/sof files and update some parameters like Modulation scheme and Frame length
I want to pass parameters to FPGA via GUI running on PC
is there a reason you have to reporgram the entire FPGA? If you could make modulation scheme and Frame length run time paramters you could simply send the updates via an RS232 link.
Reprogramming the FPGA seems a little extreme.
In which case this one is applicable:
Just use the fpga vendor provided tools for this. Assuming for the moment they have a tcl api for it you can do your gui in Tcl/Tk.
Another option is to use tool that can be launched from command line with options specifying your file location. They you launch ( exec() / system(/ whatever() ) this command line tool from your gui with the proper options to tell it what files to use.
