Amalinda
Banned
I do not know whether I should use a Linear drop out voltage regulator or a Switching one like TPS63021 to gain power to my circuit using a one cell LIPO (4.2 to 3.0 V 5000mAh)
both ARM and the SIM908 module needs 3.3 volts ideally.
SIM908 requires two 2Amp bursts a day to transmit two messages a day. And the ARM M4 will be in hibernation(@4uA) and wakes up(@100mA) two times a day to "tell" the SIM908 "what" to transmit via UART. yes, this is a data transmission circuit but the difference is that this is a solution to my countries elephant human conflict from which a number of people die every year. this cct is to replace the current extremely expensive cct which uses SAT communication and this is my final year project
this provides hardware support to the already built software model (an earlier project) which is a web server and a mobile android app. I will upload data(the location of an elephant) to a web server via GPRS/SMS.
I will use the highest available mAh LIPO battery and it will be charged using SOLAR/Kinetic energy which I havent thought about yet.
I understand that a LIPO battery has a voltages life per cycle ranging from 4.2 to around 3.0(safe operation)
MY QUESTION
from 4.2V to 3.4V (I require 3.3V) which regulator should I use? Linear drop out? or Switching
I know there are 0.1V drop out LDRs how about them?
Or is this( TPS63021) better because this can run down till 2.5V
Your help would save a life and also help me get a good grade
thanks
MY QUESTION
thanks
