Find them under the path:
$CDS_ROOT/doc/
where $CDS_ROOT is your tools installation directory, e.g. /usr/local/CadenceTools
If you're not sure from it, you can know it if you wrote: "which icfb" without quotes in the shell.. Assuming that you run Cadence by typing icfb
It contains folder for each document in both pdf and HTML formats..
after you bring up cadence command window, you should be able to see "help" around the top right corner. then you can find what you want.
or, type cdsdoc at the UNIX prompt to bring up the Cadence on-line documentation. Choose the "Composer" option from the main page. Then select "Virtuoso Schematic Composer Tutorial."
