Where can I get a TD1509 or its replacement?
mbservice.org.uk
Newbie level 6
Newbie level 6
Ipswich
Hi all I am looking for this subject and if you have some one scheme for picture frame I need
TD1509
I don't understand your question, but on the off-chance this is the answer - here is the data sheet for the TD1509:
radio-hobby.org/uploads/datasheets/td/td1509.pdf
Keith.
Re: TD1509
Sorry for my English and thanks for your kind but I have datasheet I need buying this part. I was trying in china but he wanted send me 20 pieces :) or some replacement
TD1509
Assuming that is the correct part, you could contact Techcode and ask where you might get one in the UK. Ask nicely and they might post you a "sample".
Keith.
TD1509
maybe thes helps:
w*w.111ic.com/icdz/TD1509.html
w*w.iccpp.com/IC/TD1509.shtml
K.
TD1509
i meant to show the link to their website:
Keith.
TD1509
Under my search for TD1509; i found a forum wher sombody told taht he called & emailed moretimes the techcode & received noting as answer:-(...
If their are "so nice", maybe is better to forget for some new development...
K.
Re: TD1509
No problem mate we will see :) thanks for your kind
Added after 2 minutes:
also look here that can by replacement but it has other legs :)
TD1509
Hi fun,
The pinout difference isnt much & for a price of ca. 3-4$ its to redesign/change layout: real not (so) a problem as a problematics component (& maybe more expensive too) to handle & buy...
K.
Re: TD1509
Yes probably I will thinking about it :) I am going to find some where this component
TD1509
Yes, in my opinion its a rentable job:), check it here pls, you has a lot of sources not so as by TDxxx:
https://octopart.com
K.
TD1509
And what do you need maximum?
Her can you search & calculate parameters & prices as versions too:): w*w.national.com/analog/power/simple_switcher
These web side is real good to use...
K.
TD1509
Hallo,
LM22670 (3A9 &22680 (2A) for 4.5--42V Outs are, as DIP/PSOIC8 & TO263-7pin, similar architecture but other pinout!
I think the LM3102(2.5A) & 3103 (0.75A) are even good alternative types, but (as usual); pinout differencies...
K.
