Whats the equivalent string for the enter key for a micro?
chardbiggie
Junior Member level 1
how to send enter key
i am using a ds89c420 microcontroller to answer a cal via modem, the at command for answering a call is ATA, so i burn the command print "ATA" to my microcontroller( i am using Basic language) , the problem is that for the modem to execute the command an enter key or carriage return must be executed how will i burn this to a microcontroller...
in short the enter key what is its equivalent string or how would i burn it on a microcontroller
hope u guys could help
Re: how to send enter key
In most cases, the <Enter> key is normally associated with the carriage return, which is denoted by ASCII character 13.
The equivalent hexadecimal sequence of <cr><lf> is 0x0D 0x0A, or if you want in decimal, 13,10. Just send this using SBUF and it will work.
yeah i already read that how would i execute it using BASIC language?
would
print "ATA"
print "13"
do the trick?
how????
please help thanks!!!!
The last time I coded in BASIC is at least a decade ago. Anyway, I remember BASIC uses the chr$(13) function. Not too sure about PICBASIC. According to **broken link removed**, they did mention a chr() function. Probably it's the same.
