nicleo
Advanced Member level 2
Re: Ferrite cores help
Based on your explanation, the driving mosfet is HOT when driving the toroidal core. At mosfet site, power loss (and therefore heat) is from switching loss and conduction loss. What is the duty cycle of your 20kHz switching signal?
Yup ... there will be 'eddy current' loss, which is frequency dependent (higher frequency, higher loss). However, ferrite power core is designed for high frequency application, so the loss at high frequency will be lower compared to soft-iron laminated core.rx5 said:1. 4+4 pri, 16T+16T
2. 12V in, out should be 12V x 4 = 48V
3. 20khZ
4. the magnet wire did not get hot
5. 1 pc 1.25" toriod only
i will try to increase the turns ratio.. maybe 6T+6T pri and 24T + 24T on secondary...
one more thing, are E-I cores and toriods frequency dependent? i mean does driving a toriod @ 20khz, make it more "heating up" ?? or should i increase frequency ??
