What to consider for modem to 8051 connection ?
ricpax
Newbie level 3
Newbie level 3
hi! my question is what are the things we have to consider in order to achieve a connection b/w a remote pc(using hyperterminal) to a 8051 (connected to a external modem) via telephone line..
connection goes this way:
pc(hyperterminal)<--->modem<--->telepone line<--->modem<--->8051
thanks!!
Re: modem to 8051 connection
you have to consider a lot of things, you should use rs232 (max232)
also read about haye's AT commands and rs232 interfaces
    ricpax
There is one of today's topics on: modem's AT commands and 8051.
It is alost the same issue as yours.
Have a look...
use serial port interfaced modem and intrface cpu with it through AT commands,it is simple and works!...
If you using just Rx and Tx dont forget to set NO FLOW CONTROL on modem on mcu side.
Mr.Cube
in relation to my first querie..
we tried to test it first by connecting the µcontroller directly to the serial port of the PC(without using modem and telephone lines)it actually works..
then,we tried to connect two pc(hyperterminal)both have modems, using the telephone line inorder for us to test the connectivity of both modems..connecting pc to pc was quite easy. But since our project requires communication b/w pc and microcontroller,we find it very hard for the pc and the µcontroller to achieve handshaking,because we could not make the µcontroller to answer the call..what should we consider first in order to handshake?
since the project of ricpax and mine is almost the same, just like to ask if i burn the command -->print "ATA"
in the 8051 will the microcontroller answer the modem? im using 3 wire connection only the RX, TX and Grnd
please help...
