What rating of TVS diode is suitable for a 220/240 Vac pump?
Akanimo
Advanced Member level 3
What rating of TVS diode is suitable for a 220/240 Vac 1.5-HP pump?
Hi all,
I have a 220/240 Vac, 1.5 HP pump that I am to drive with a relay. I want to suppress the transient voltage and consequent current that will occur (due to the pump coil) at the relay contacts when the contacts are opened using a TVS diode. Which is suitable, 1.5-kW or 3-kW TVS diode?
Re: What rating of TVS diode is suitable for a 220/240 Vac 1.5-HP pump?
Or should it be a higher rated TVS, perhaps 5kW or 15kW? Or is it a bad idea altogether?
Any more information I should add?
Any contribution will help.
What do you think?
Thanks in advance for responding.
--Akanimo.
As far as I'm aware of, TVS diodes are not intended to be used with mains power supply, although this might possible with proper fuses disconnecting it in case of failure. It's more common to use RC snubbers (with respective X2 capacitor rating) or MOV to suppress contact arcing.
Thanks for your response FvM. I had an RC snubber across it already but it didn't seem to be effective enough by itself. That's why I thought of adding the TVS diode also. The components were likely not of moderate values. I will try and optimize the values.
Thanks once again.
