[ARM] What is wrong with this code "LPC2148 keypad,LCD, ibutton"
amitjagtap
Full Member level 5
hi all,
I have written code for ibutton access control system using LPC2148. Individually all worked fine.
when integrated, it behaves different. I have tried several changes in that I dont know what thing I am missing.
as per code flow : it should display choice of Registration phase and user access phase, but it is directly jumping to user accress phase without going to registration phase....
Logically code looks ok...
Experts of ARM and Embedded C: please comments on ant loop holes...
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
#include "lcd.h"
#include "i2c.h"
#include "lpc214x.h"
#include "type.h"
#include "serial.h"
#define UART0_TEXT "\n\r I-BUTTON ACCESS CONTROL SYSTEM"
#define PRESCALE 30 // to generate 1us interval-- Each TC will count 1us
extern void init_PLL(void);
extern void UART0Init( DWORD baudrate );
extern void delay1(unsigned int);
unsigned char getKey(void);
void initRTC(void);
extern void initTimer0(void);
unsigned char IBReset(void);
void IBWriteBit(unsigned char bit);
char IBWriteByte(unsigned char data);
unsigned char IBReadBit(void);
unsigned char IBReadByte(void);
void delayus(unsigned int);
char keys[4][4] = {
  {'1', '2', '3', 'A'}, //1,2,3,4
  {'4', '5', '6', 'B'}, //5,6,7,8
  {'7', '8', '9', 'C'}, //9,10,11,12
  {'*', '0', '#', 'D'}  //13,14,15,16
int main (void)
{  char ibuf[8],PIN[4],Read_key[8],Read_PIN[4];
   unsigned int k,readibutton_done;
   char key;
   char *strng="\t *** \n";
   //unsigned int i;
   init_PLL();
   init_lcd();
   initRTC();
   IODIR0 |= 0x00FF0000;                //P1.23 to P1.20 as Output- //P1.16 to P1.19 as Input For Keyboard
   IOCLR0 |= 0x00FF0000;
   IODIR0 ^= 0x00F0000;
   //IOPIN0 ^= 0x000F0000;         //0x00FF0000;
    PINSEL0 = 0x00000005;       /* Enable RxD0 and TxD0  & TXD1 & RXD1 */
    UART0Init(9600);
    uart0_puts (UART0_TEXT);
    uart0_puts (strng);
    uart0_putc ('\n');
    for (k=0;k<8;k++)    // Clear The ibutton buffer
          ibuf[k] = 0;
          key = 0;
  i2c_lpc_init(I2C_SPEED_100);  // I2c init for EEPROM Speed 100Ksps
  delay1(5000);
  lcd_clear();
       lcd_putstring(0,"I-BUTTON ACCESS ");
       lcd_putstring(1," CONTROL SYSTEM");
       delay1(8000);
  while (1)
      lcd_clear();
      lcd_putstring(0," #-T0 REGISTER ");
      lcd_putstring(1,"UserAccess-Any ");
      delay1(8000);
        while(!(key = getKey()));   // wait for key to press
     //switch(key)     // User Registration Phase
       if (key == '#')
        //case '#':
                 lcd_clear();
                 lcd_putstring(0,"  REGSTN PHASE  ");
                 lcd_putstring(1,"  HOLD I-BUTTON ");
                 delay1(6000);
            // Read I-button
        readibutton_done = 0;
       while (IBReset()) // if i-button present function returns 1 else /0 - Null
             delayus(10000);     // wait for 10 ms - to stable the contact bounce
             IBWriteByte(0x33);  // send ROM Read command
                do {
                    IBWriteByte(0x33);
                    for (k=0;k<8;k++)
                        ibuf[k]=IBReadByte(); // Read 64 bit= 8byte Code
                while (ibuf[0]==0);
              readibutton_done = 1;
             uart0_puts ("\n \t I-Button Present"); //Debug Message
          }   // End of i-button while
        while (readibutton_done == 1)
           {     lcd_clear();
                 lcd_putstring(1,"ENTER PIN -");   // Ask to Enter PIN in Registration phase
                delay1(6000);
                 while(!(PIN[0] = getKey()));    // Read 1st key pressed in PIN[0] & display * on LCD for it
                  lcd_gotoxy(1,12);
                  lcd_putchar('*');
                 while(!(PIN[1] = getKey()));
                  lcd_gotoxy(1,13);
                  lcd_putchar('*');
                 while(!(PIN[2] = getKey()));
                  lcd_gotoxy(1,14);
                  lcd_putchar('*');
                while(!(PIN[3] = getKey()));
                  lcd_gotoxy(1,15);
                  lcd_putchar('*');
                 m24xx_write(EEPROM_24XX256, 0 , 0 ,(char *)ibuf , sizeof(ibuf));   // write key 8 bytes to EEPROM  from location 0 to 7
                 m24xx_write(EEPROM_24XX256, 8 , 0 ,(char *)PIN , sizeof(PIN));   // Store 4 digit PIN  in EEPROM from 8 to 11
                 //send key & PIN to host PC
                    uart0_puts("\n\t Registered I-button key  & PIN -\t");
                 for (k=0;k<8;k++)
                    { uart0_putc(ibuf[k]);
                      ibuf[k] = 0;       // Clear Key Buffer
                     uart0_putc('\t');
                 for (k=0;k<4;k++)
                    { uart0_putc(PIN[k]);
                      PIN[k] = 0;            // Clear PIN Buffer
                 lcd_clear();
                 lcd_putstring(0," REGSTN DONE ");
                 delay1(50000);
                 key =0;    // To activate User Access Phase after registration
             // break;
        else if (key == '*')  //case '*':  // User Access Phase
           {      lcd_clear();
                  lcd_putstring(0,"   USER ACCESS  ");
                  delay1(50000);
                  //Read ibutton
                      do {
                          IBWriteByte(0x33);
                          for (k=0;k<8;k++)
                       while (ibuf[0]==0);
               m24xx_read(EEPROM_24XX256, 0 , 0 , (char *)Read_key , sizeof(Read_key));     // Read ibutton stored Key
               if (Read_key != ibuf)  // If Read Key form EEPROM and ibutton key not matched
                { lcd_clear();
                  lcd_putstring(0,"I-BUTTON UNREGIS");
                  lcd_putstring(1,"   NO ACCESS    ");
                  delay1(8000);
                   //send Unregistered i-button key to host PC as unauthorized Access
                  uart0_puts("\n\t UnAuthorized Access with Key -\t");
                  for (k=0;k<8;k++)
                   uart0_puts("\n\t UnAuthorized Access at Time -\t");
                   uart0_putc(YEAR/100);
                   uart0_putc(YEAR%100);
                   uart0_putc (':');
                   uart0_putc((MONTH));
                   uart0_putc (':');
                   uart0_putc(DOM);
                   uart0_putc (':');
                   uart0_putc(HOUR);
                   uart0_putc (':');
                   uart0_putc(MIN);
                   uart0_putc (':');
                   uart0_putc(SEC);
              else if (Read_key == ibuf)     // if i-button is matched Ask to Enter 4 digit PIN
               {   lcd_clear();
                   lcd_putstring(1,"ENTER PIN -");   // Ask to Enter PIN in  user Access phase
                      lcd_gotoxy(1,12);
                      lcd_putchar('*');
                      lcd_gotoxy(1,13);
                      lcd_putchar('*');
                      lcd_gotoxy(1,14);
                      lcd_putchar('*');
                      lcd_gotoxy(1,15);
                      lcd_putchar('*');
                   // Read PIN
                      m24xx_read(EEPROM_24XX256, 8 , 0 , (char *)Read_PIN , sizeof(Read_PIN));      // Read stored PIN  from EEPROM
                   if (Read_PIN != PIN)  // compare stored PIN and Entered PIN
                         lcd_clear();
                         lcd_putstring(0,"   WRONG PIN   ");
                         delay1(8000);
                         //send Wrong PIN  ibutton key to host PC as unauthorized Access
                         uart0_puts("\n\t Wrong PIN with Key -\t");
                           for (k=0;k<8;k++)
                         uart0_putc (':');
                         uart0_putc (':');
                         uart0_putc(DOM);
                         uart0_putc (':');
                         uart0_putc(HOUR);
                         uart0_putc (':');
                         uart0_putc(MIN);
                         uart0_putc (':');
                         uart0_putc(SEC);
                         for (k=0;k<4;k++)
                             PIN[k] = 0;
                  else if (Read_PIN == PIN)
                   {  lcd_clear();
                      lcd_putstring(1," ACCESS Granted");
                      delay1(10000);
                      //  set GPIO or Buzzer here
                        IODIR1 |=0x02000000; // P1.25 Buzzer is connected
                        IOSET1 |= 0x02000000; // make it high
                        delay1(50000);
                        IOPIN1 ^= 0x02000000; // make it low
                         uart0_puts("\n\t Access Granted to Key -\t");
                           for (k=0;k<8;k++)
                         uart0_puts("\n\t Access Time -\t");
                         uart0_putc (':');
                         uart0_putc (':');
                         uart0_putc(DOM);
                         uart0_putc (':');
                         uart0_putc(HOUR);
                         uart0_putc (':');
                         uart0_putc(MIN);
                         uart0_putc (':');
                         uart0_putc(SEC);
   }  ///End of While
}  ///End of Main
/***********************************************  PLL0 Initialization *************************************/
void init_PLL(void)
PLL0CFG = 0x24; // Set multiplier and divider of PLL to give 60.00 MHz .... 4:0 - MUL Value => 4+1=5, 6:5 - Divide Value = 1+1= 2
PLL0CON = 0x01; // Enable the PLL  -- Bit 0 = PLL Enable
PLL0FEED = 0xAA; // Update PLL registers with feed sequence
PLL0FEED = 0x55;
while (!(PLL0STAT & 0x00000400));  // test Bit 10 = Lock bit
PLL0CON = 0x03;   // Connect the PLL      --- Bit 1= PLL Connect, Both bits 0 & 1 should be 1 to use PLL
PLL0FEED = 0xAA;   //Update PLL registers
PLL0FEED = 0x55;
VPBDIV = 0x02;    //Set the VLSI peripheral bus (APB or PCLK) to 30.000MHz
return;
/***********************************************  RTC Initialization *************************************/
// Initialize RTC - Current time values should be added
void initRTC(void)
   { // ILR = 0x01;
     // CIIR = 0x01; // Enable Interrupt on Sec increment
      CCR = 0x10;  //  0 - To write the time value,  bit 4 = '1' to select source as Ext 32.786 KHz
      // Write the current time and calander date
      SEC = 45;
      MIN = 15;
      HOUR = 2;
      DOM = 31;
      DOW = 6;
      DOY = 365;
      MONTH = 4;
      YEAR = 2014;
      CCR = 0x11;  // Enable the RTC counters
void delay1(unsigned int count)
unsigned int i,j;
for(i=0;i<count;i++)
   for(j=0;j<2000;j++);
/*********************************************** Keypad Read Function *************************************/
    //while(1)
      IOCLR0 |= 0x00F00000;
      IOSET0 |= 0x00100000;
    if(((IOPIN0 &0x000F0000)>>16) == 0x08)
            { delayus(10000);
                  while (((IOPIN0 &0x000F0000)>>16) == 0x08)
                     delayus(10000);
                     return(keys[3][0]);
        else if(((IOPIN0 &0x000F0000)>>16) == 0x04)
            { delayus(10000);
                  while (((IOPIN0 &0x000F0000)>>16) == 0x04)
                    delayus(10000);
                    return(keys[2][0]);
        else if(((IOPIN0 &0x000F0000)>>16) == 0x02)
           { delayus(10000);
                  while (((IOPIN0 &0x000F0000)>>16) == 0x02)
                    delayus(10000);
                    return(keys[1][0]);
        else if(((IOPIN0 &0x000F0000)>>16) == 0x01)
             { delayus(10000);
                  while (((IOPIN0 &0x000F0000)>>16) == 0x01)
                    delayus(10000);
                    return(keys[0][0]);
       IOCLR0 |= 0x00100000;
         IOSET0 |= 0x00200000;
             { delayus(10000);
                    delayus(10000);
                    return(keys[3][1]);
                { delayus(10000);
                    delayus(10000);
                    return(keys[2][1]);
           { delayus(10000);
                  delayus(10000);
                  return(keys[1][1]);
           { delayus(10000);
                  delayus(10000);
                  return(keys[0][1]);
       IOCLR0 |= 0x00200000;
     IOSET0 |= 0x00400000;
             { delayus(10000);
                    delayus(10000);
                    return(keys[3][2]);
                { delayus(10000);
                  delayus(10000);
                  return(keys[2][2]);
           { delayus(10000);
                  delayus(10000);
                  return(keys[1][2]);
           { delayus(10000);
                  delayus(10000);
                  return(keys[0][2]);
            }     IOCLR0 |= 0x00400000;
     IOSET0 |= 0x00800000;
             { delayus(10000);
                    delayus(10000);
                    return(keys[3][3]);
                { delayus(10000);
                  delayus(10000);
                  return(keys[2][3]);
           { delayus(10000);
                   delayus(10000);
                   return(keys[1][3]);
           { delayus(10000);
                  delayus(10000);
                  return(keys[0][3]);
        else return 0;
  • main.txt
I think the code seems to be written correctly...but I cannot discern,even after reading the code,why it is jumping to user access phase without going through the registration phase..
which display you are using??
post full project for better help
