40250 Transistor Datasheet. Parameters and Characteristics.
Type Designator: 40250
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 29
Maximum collector-base voltage |Ucb|, V: 50
Maximum collector-emitter voltage |Uce|, V: 50
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 4
Maximum junction temperature (Tj), °C: 200
Transition frequency (ft), MHz:
Collector capacitance (Cc), pF:
Forward current transfer ratio (hFE), min: 25
Noise Figure, dB: -
Package of 40250 transistor: TO66
1. 2N4232 Si NPN 35 70 60 5 5 200 25 TO66
2. 2N4233 Si NPN 35 90 80 5 5 200 25 TO66
3. 2N4233A Si NPN 75 80 80 5 5 200 25 TO66
4. 2N4301 Si NPN 50 100 80 8 10 200 30 TO66
5. 2N5427 Si NPN 40 80 80 6 7 200 30 TO66
6. 2N5428 Si NPN 40 80 80 6 7 200 60 TO66
7. 2N5429 Si NPN 40 100 100 6 7 200 30 TO66
8. 2N5430 Si NPN 40 100 100 6 7 200 60 TO66
9. 2N6233 Si NPN 50 250 225 6 5 200 25 TO66
10. 2N6234 Si NPN 50 300 275 6 5 200 25 TO66
11. 2N6235 Si NPN 50 350 325 6 5 200 25 TO66
12. 2N6235R Si NPN 50 300 275 6 5 200 25 TO66
13. 2N6261 Si NPN 50 90 80 7 4 200 25 TO66
14. 2N6294 Si NPN 50 60 60 5 8 200 750 TO66
15. 2N6295 Si NPN 50 80 80 5 8 200 750 TO66
16. 2N6300 Si NPN 75 60 60 5 8 200 750 TO66
17. 2N6301 Si NPN 75 80 80 5 8 200 750 TO66
18. 2N6534 Si NPN 36 80 80 5 15 200 1000 TO66
19. 2N6535 Si NPN 36 100 100 5 15 200 500 TO66
20. 2N6536 Si NPN 36 100 100 5 15 200 1000 TO66
21. 2N6537 Si NPN 36 120 120 5 15 200 1000 TO66
22. 2S043 Si NPN 35 100 80 8 5 200 30 TO66
23. 2S044 Si NPN 35 100 80 8 5 200 60 TO66
24. 2S045 Si NPN 35 150 120 8 5 200 30 TO66
25. 2S046 Si NPN 35 150 120 8 5 200 60 TO66
26. 40250 Si NPN 29 50 50 5 4 200 25 TO66
27. BDY71 Si NPN 29 90 55 0 4 200 80 TO66
28. BUR10 Si NPN 30 100 80 8 5 200 40 TO66
29. BUT30 Si NPN 250 200 125 0 100 200 25 TO66
30. BUT32 Si NPN 250 400 300 0 80 200 25 TO66
31. BUX77 Si NPN 40 100 80 6 5 200 50 TO66
32. BUX77A Si NPN 40 100 80 6 8 200 30 TO66
33. NTE274 Si NPN 50 80 80 5 4 3000 TO66
34. RCA1C05 Si NPN 40 140 120 5 4 200 40 TO66
35. SK3026 Si NPN 29 90 60 7 4 200 70 TO66
36. SK3538 Si NPN 40 160 140 7 4 200 30 TO66
