what is the meaning of AVCC and AREF pins in atmega8
achuth002
Junior Member level 3
hyderabad
hi all
i will not understading the AVCC amd AREF pins in atmega8
explane the above pins of the atmega8
and use of the pins in atmega8 mixro controller
thanks all
hi all
thanks all
These pins are connected to the ADC module.
AVCC is the supply voltage and AREF sets the reference voltage that can be diferent from AVCC.
But in many cases the both are connected to Vcc ...
:wink:
IanP
i know ur rply
but what is the purpose of this pins
i mean why are connected to any compentnt in ground
and in case connected to any filetrs are connected
other uses
thnks all
AVCC and AREF are ADC VCC and ADC REF Voltage pins. They provide voltage and reference voltage to adc circuit in the chip.
other uses
I didn't understand what you are saying.
The purpose of AVCC pin is that, it gives supply voltage to internal ADC module. And AREF pin is use for ADC reference. For example if you ADC module in ATmega8 , for external reference to ADC we can AREF pin.
