What is the Lex & Yacc tool ?
Lex & Yacc
http://dinosaur.compilertools.net/
A compiler or interptreter for a programminning language is often decomposed into two parts:
1. Read the source program and discover its structure.
2. Process this structure, e.g. to generate the target program.
Lex and Yacc can generate program fragments that solve the first task.
The task of discovering the source structure again is decomposed into subtasks:
1. Split the source file into tokens (Lex).
2. Find the hierarchical structure of the program (Yacc).
Re: Lex & Yacc
Any clue to where I can get this stuff from ? .. I can't find any download link in the link u mentioned !
Re: Lex & Yacc
Any unix OS have lex and yacc.
In linux it named flex and bison .
There are also Windows versions.
Re: Lex & Yacc
can u help me downloading the windows version ? .. is it under cygwin environment ?
Lex & Yacc
Cygwin is one way. Or try searching Google for lex yacc windows
Reactions: blooz
    blooz
Re: Lex & Yacc
There is a pure windows port Flex & Bison. Its a part of BisonFlex wizard for Visual C++ 6.0. It can be found for example at h**p://www.window95.com/windows/programming.html
But main problem with Flex/Bison is a license. All programs that use Flex/Bison must be GNU.
