jani12
What is the effect of 100 microseconds(us) transient in a automobile battery?
A typical embedded system, let's say Transmission or Power Train Electronic Control Unit (ECU) is powered by automobile Battery.
Battery voltage is at 12 Volts. If the battery voltage drops to 0 Volts in 5 us and stays at 0 V for 100 us, then rises back to 12V in 5 us, what impact will this have on Microcontroller memories, different microcontrollers inputs like Analog, Digital, PWM, etc. And different outputs like Digital, PWM etc.
Will the contents of I/O and memories like SRAM, Program Flash, Data Flash change due to this transient?
The microcontroller on the ECU is Infineon Aurix TX29x.
Correction! The Microcontroller is Infineon Aurix Tricore TC29x
