[SOLVED] What is a pocket implant and where is it used?
prcken
Advanced Member level 1
Shanghai
can any body tell what pocket implant it is on earth
what is good for? and what is the disadvantage
thanks
pocket implant
Pocket implants are used to avoid Punch through effects in short-channel devices. they are heavily doped (unlike LDD) small regions of substrate at the edges of drain and source regions to avoid depletion regions of drain and Source to pronounce into channel
pocket impant
depletion regions of drain and Source to pronounce into channel is also called drain-induced barrier effect(DIBL)?
pocket implant?
DIBL is the effect due to the High Strongly inverted and high Vds voltage.
This punch through effect is without them
Reactions: prcken
    prcken
