what is a marginal design mean in fpga? how to overcome this?
VLSI_CHE
Junior Member level 1
can anyone explain what is a marginal design in fpga? why does that happen? what to do to overcome this problem?
A design that just barely works. Or one that 'usually' works, but fails under certain conditions
Usually the cause is inexperience of the designer
- Have the design reviewed by an experienced designer
- Learn from experienced designers
Kevin Jennings
what kind of design mistakes need to be taken care of , in order to avod such margnal designs...
Avoid latches
Make sure all logic is synchronous
use proper techniques for crossing clock domain boundaries.
These are the biggest two problems.
ca u plz suggest some guidelines for planning my clocks inside fpga..
Basically, try and minimise the number of clocks. Keep clock domain crossings to a minimum. And when you do, use a DCfifo.
dual clock FIFO. It uses a memory as a buffer between the clock domains.
