Magnethicc
Member level 2
Hi everyone,
I want to understand the reasons for voltage to appear between primary and secondary and the reasons that affects this voltage magnitude.
Inorder to design a compliant power supply one needs to keep isolation distances between primary and secondary circuits. But in order to get the correct distances one needs to built the power supply and measure the voltage between the primary and secondary and then follow the safety standard to redesign the islation distances if necessary.
1. Is there any way to anticipate the isolation distances needed between the primary and secondary circuits?
2. What is the reason for the voltage between primary and secondary (maybe parasitic capacitance between primary winding and secondary winding?)
3. What can make this voltage larger or smaller? (Turns ratio? Number of turns? Input/output voltage?... dV/dt?)
4. Any piece of knowledge or information you want to share is highly appreciated!
Thank you.
Thank you.
