What exactly is the At Speed Test ?
shwetha100
Junior Member level 1
Florida
Can someone clearly explain what at speed test is? I have found similar posts on this website but couldn't get to a post where I understood what it is all about.
Thanks.
Re: At Speed Test
Normally test clocks have low frequencies. At these frequencies basically you can check the connectivity of the nets (e.g. shorts/opens). However you cannot see the real parasitic effects of a functional clock which has higher frequency than test clocks.
At this point using at-speed-clock, which means running the circuit at its functional frequency, you can gather more information (e.g. path delay) and improve the coverage.
Best regards,
Gokhan
Re: At Speed Test
At speed test scan generates two clock cycles for the capture cycle at functional frequency.
Re: At Speed Test
At speed test are used in analyzing path delay/transition delay of circuit. Normal tests are good to test 'stuck at' faults but they fail in testing timing behavior of circuits.
