what does STANDARD 0.35micron n-well process means?
allennlowaton
Full Member level 5
Taiwan
hello guys..
I have a paper here with the following data:
Vin range: 1.2V - 3V
Vout range : 3.6V - 6V
It was implemented using the STANDARD 0.35micron n-well process.
The 0.35micron has 3.3V and 5V. In this case, what do you think
the author used in this process? 3.3V or 5V. I can't find it in the paper.
They just said they used a standard 0.35micron n-well.
Thank you guys...
Dual Voltage processes - very common -
Look for any Voltage Shifter or power adapter elements that does 3.3V / 5V up/down conversions.
-- adam
I assume that this paper uses the 5V option of the 0.25micron process.
But it just said, they're using the standard 0.25micron process.
Did they used 2.5V or 5V? I'm confused...
---------- Post added at 06:31 ---------- Previous post was at 06:28 ----------
sorry..it should be 3.3V or 5V..
---------- Post added at 06:57 ---------- Previous post was at 06:31 ----------
another question: I will be having this data in my design, Vin (2.7~4.2) and Vo(3.5~5.0).
Can I used the 2.5V of the 0.25micron process?
thank you..
