What does "FB23 220R" mean next to an inductor?
hobbskw
Junior Member level 3
Hello,
I am reading a schematic and noticed an inductor symbol that said "FB23 220R" next to it.
What does this mean? I cannot find any inductor that has part# FB23, and I thought 220R would be for resistance, not inductance.
maybe you should show us the picture/schematic you have seen.
Klaus
FB23 is probably the reference designator. 220 micro Henry, maybe.
Actually it's probably a ferrite bead with 220 ohm impedance , or maybe 22 ohm.
Most SMD ferrite beads are specified by their resistance. If you are reading a schematic, look for FB22 or FB21 etc. If you can locate them, it may just be a component identifier (23 being a serial number). These SMD components do not have inductance values explicitly specified. They suppress high frequency noise reasonably well.
220R at 100Mhz.
This is ferrtie bead. Like inductor but core lost + wire lost follow frequency of current through it.
It use for filter noise in a specific of frequency range.
Does not effect with small dc current.
Higher xxxR value will make dc resistance increase ,then dc acceptable current is smaller.
"high frequency" - that is only half story.
If frequency higher max frequency, its impedance reduce.
Select correct ferrite bead only apply for a frequency range.
Insert ferrite bead can reduce high frequency is true. In other side it also increase amplitude of basic(low) frequency. Need a damper RC or R // RB to reduce this ringing to build the best filter.
