taolibuyan
Newbie level 3
Xilinx ISE 8.1i gives me this message:
INFO:Xst:2387 - HDL ADVISOR - A 2-bit shift register was found for signal <vid_byp_reg1<0>> and currently occupies 2 logic cells (1 slices). Removing the set/reset logic would take advantage of SRL16 (and derived) primitives and reduce this to 1 logic cells (1 slices). Evaluate if the set/reset can be removed for this simple shift register. The majority of simple pipeline structures do not need to be set/reset operationally.
(This message repeats for every bit of vid_byp_reg1.)
The related codes are:
always @(posedge mclk_p or posedge rst)
begin
if (rst) vid_byp_reg1[9:0] <= #(1) 10'b0;
else if (pclk_en) vid_byp_reg1[9:0] <= #(1) vdi_reg[9:0];
end
begin
if (rst) vid_byp_reg2[9:0] <= #(1) 10'b0;
else if (pclk_en) vid_byp_reg2[9:0] <= #(1) vid_byp_reg1[9:0];
end
begin
if (rst) vid_byp_reg3[9:0] <= #(1) 10'b0;
else if (pclk_en) vid_byp_reg3[9:0] <= #(1) vid_byp_reg2[9:0];
end
Does this message mean I can simply remove the reset statement? Why does this message only occur for vid_byp_reg1, not for the other registers?
The program is using more than 100% of resources. So it would be great to reduce the slices the register uses. Thanks.
begin
end
begin
end
begin
end
