I am not sure about fmax.
But for ft, it represents the theoretical highest speed of a single transistor can give (applicable to small signal only).
However, in real life, there are several limitations that prevent you to achieve that kind of theoretical highest speed:
1. You need gain. Gain and Speed is always a trade off
2. ft actually varied with current. You can plot ft vs current (a curve like a mountain) that tells you what is the optimum bias current for a give transistor size to obtain highest ft.
3. Transistor has parasitic cap. bias current increases -> transistor size increases -> parasitic cap increases -> speed reduces
In general, ft is determined by process. I think to achieve 1/20 of ft speed, should not be a problem over all corners. However, to achieve something less than this, you may need to carefully design the blocks and consider some speed enchancement or bandwidth doubler architectures.
for a ft doubler, the unity current gain cut-off frequency is doubler.....this not mean the output frequency also double? can this ft doubler circuit be used to multiply frequency?
ft is called transit freq. fo trans. and theoreticaly speaking it is also Fmax for trans.
and for deisgn purposes we take ft/10 to be the frequecny upto which our trans. will work fine...beyond that there may be no guarantee.
Hello all,
can anyone tell intuitively the physical signficance of fT? I mean are we trying to see how fast the channel charge can respond to change in gate current?
finally where does gate leakage come in picture?
thanks so much for the help
thanks,
