wavguide filter with bend?is it ok?
amicloud
Full Member level 2
I designed a filter with no bend firstly, and I directly change the filter to one with bend, and place one inductive iris inside the bend,but the result is very poor.how to improve?
hi
i have done that for waveguide filters, by HFSS. I optimized the filter's post. and the bend, using hfss's optimization ans sweeps. It took some time.
sara
when you change the structure of you design , it is necessary to tuning the filter in the simulator. the optim in HFSS is very powerful but it is very time-comsuing.
I find a new method to design every resonator-coupling filter including iris waveguide filter . it is very efficient and accuracy. I have designed a 20pole filter using this method though it is unrealizing(maybe using superconductor).
I will post it on the forum if anyone want to see it .
