Warning when simulating monopole antenna with CST
xxgcatz
cst help
When i simulate monopole antenna with cst. There is a waring:"Port number 1 has very few transversal points to calculate the desired number of modes.This may lead to inaccurate mode patterns." who can tell me what reason causes that. thanks a lot
cst help
when you post ur MWS-files(*.mod; *.par), maybe could i help u.
cst help
You have very draft meshing (too low cells number) in port region. Increase the meshcells number in port region. But it is not without fail, if You need to take into account only one (main) mode at this port (of course, if You think that the current meshcells number is enough to right calculation of main port mode).
Best regards,
Kit-the-great
Re: cst help
You didnt choose correct the ground points of the port.
