chxgzl4862
Member level 1
why this warning?
hello !
Note: This design contains no timing constraints.
Note: A default set of constraints using a delay of 0.000ns will be used for
analysis.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1000 =
PERIODERIOD_SPIFsmClk.Q:0.000 nS because of one of the following: (a) a
signal name was not found; (b) a signal was removed or renamed due to
optimization; (c) there is no path between the FROM node and TO node in the
TIMESPEC.
my program
entity SPI_FSM is
port (
SPI_FSM_CLKIN: in std_logic;
SPI_FSM_RST: in std_logic;
SPI_FSM_CS: in std_logic;
SPI_FSM_MOSI: out std_logic;
SPI_FSM_MISO: in std_logic;
SPI_FSM_DATAIN: in std_logic;
SPI_FSM_DATAOUT: out std_logic;
SPI_FSM_DIVNUM: in std_logic_vector ( 7 downto 0 )
end SPI_FSM;
architecture Behavioral of SPI_FSM is
component SPI_CLK
port (
SPI_CLK_CLKIN: in std_logic;
SPI_CLK_RST: in std_logic;
SPI_CLK_CS: in std_logic;
SPI_CLK_OUT: out std_logic;
SPI_CLK_DIVNUM: in std_logic_vector ( 7 downto 0 )
end component;
signal SPIFsmClk: std_logic;
begin
SPI_FSM_CLK: SPI_CLK
port map (
SPI_CLK_CLKIN => SPI_FSM_CLKIN,
SPI_CLK_RST => SPI_FSM_RST,
SPI_CLK_CS => SPI_FSM_CS,
SPI_CLK_OUT => SPIFsmClk,
SPI_CLK_DIVNUM => SPI_FSM_DIVNUM
SPI_FSM_STEP_MOSI:
process ( SPI_FSM_RST,SPI_FSM_CS,SPIFsmClk,SPI_FSM_DATAIN )
begin
if ( SPI_FSM_RST = '0' ) then
SPI_FSM_MOSI <= '1';
elsif ( rising_edge( SPIFsmClk ) ) then
if ( SPI_FSM_CS = '0' ) then
SPI_FSM_MOSI <= SPI_FSM_DATAIN;
else
SPI_FSM_MOSI <= '0';
end if;
end if;
end process SPI_FSM_STEP_MOSI;
SPI_FSM_STEP_MISO:
process ( SPI_FSM_RST,SPI_FSM_CS,SPI_FSM_MISO,SPIFsmClk )
begin
SPI_FSM_DATAOUT <= '0';
SPI_FSM_DATAOUT <= SPI_FSM_MISO;
else
end if;
end if;
end process SPI_FSM_STEP_MISO;
end Behavioral;
how can i do with it? thanks!
hello !
analysis.
TIMESPEC.
my program
entity SPI_FSM is
port (
end SPI_FSM;
component SPI_CLK
port (
end component;
begin
port map (
SPI_FSM_STEP_MOSI:
begin
else
end if;
end if;
SPI_FSM_STEP_MISO:
begin
else
end if;
end if;
end Behavioral;
