juz_ad
Full Member level 2
I'm working on a design that uses 6x of the classic Jung Voltage Clippers to block DC voltage greater than +2.5V.
They each require a +2.5V VRef where I have a choice of A) setting up a single LM-336 SOIC buffered by an SOIC Op-Amp and running all 6x VRefs off of that (or perhaps off multiple op-amp buffers as the current draw requires)... or B) using a single SOT-23 LM-4040 for each clipper.
Both methods work and I can see potential advantages/disadvantages of both approaches - so I was hoping some people here might be able to offer some advice on the best approach.
Op-amps are powered by +/- 12V, input signals to clip will be between 0-10V and 1Hz to 10KHz.
[Edit] - Trying to keep current draw and long/complex PCB traces to a minimum are both priorities here.
Thanks!
Thanks!
