internetuser2k12
Banned
If your 0-5 volts at mcu pin is scaled and the actual range = 0-20v then 5 = 20
so 1v scaled = actual 4v
Your adc will produce 1023 raw value for 5v i.e., 20v actual value.
5v scaled = 20v actual = 1023 raw adc value
you can write like 1023 * x = 5
x = 5 / 1023 = 0.0048875855327468
raw_adc_value * 0.0048875855327468 = scaled voltage
if raw_adc_value = 819 then 819 * 0.0048875855327468 = 4.002932551319629 = 4v scaled value
raw_adc_value * 0.0048875855327468 * 4 (in this case) = actual voltage
If that 4v scaled value is multiplied by 4 it becomes 16.01173020527852 = 16v because 20/5 = 4. So you multiply by 4.
eg: if raw_adc_value = 819 then 819 * 0.0048875855327468 * 4 = 16.01173020527852 actual voltage
