Voltage Level Translator
josipb
12 to 5 level translation
I want to design a unidirectional voltage level translator, that translates high logic level signals from 3 to 12 V to level of 5 V.Can anyone help me?Exist links that explain how to make the circuit?
high voltage level translator
it seems that you want to convert the logic of voltage i.e you are using RS232 to CMOS level
so go for max232 voltage level converter IC
check the data sheet you will probably get the answer
how to build a level translator
Thanks for the quich answer.
But I must convert only the high voltage level from range between 3 to 12 V in a level of 5 V. The low voltage level must be left on 0 V. It is possible to design a simple circuit (with one or two transistors) that performs this translations?
rs232 cmos 2.8v circuit
you can make a comparator circuit using opamp
compare the level with a voltage of 2.8V and gives a supply of 5V to the IC
so whenever you will get a higher voltage you will get a 5V o/p else 0V
single supply level translator
A good idea! Thanks another time for the rapid answer!
voltage-level translator
This might help.
Single supply level shifter.
